6.5 gear reduct starter
i was think of buying them three of them two for two current projects i have going and then one spaer.
You'll also need the gear reduction bracket if you are converting from direct drive. Costs less than 15$ It will bolt on and work without the bracket, But I've heard it can tear the mounting ears off the block without the proper support.
Part number- GM 23502557
oh i know i have seen what happens to a 6.5 hummve block when u DONT put that brace on. and yes it can and will break that hole ear off the engine.
