Also try to remove your optical sensor connector and reinstall it. Corrosion often sneaks it's way in to the connectors and remove/install gets you good contact again. The optic sensor can be part of the "reference error" as the PCM compares the Optical sensor pulse to the crank sensor pulse. If the PCM "sees" something it isn't expecting you get a reference error. It knows something is wrong, just not what.
Air in the lines can also cause a code 18. The optical sensor can't "see" through aerated fuel well, it needs straight fuel. This could be something as simple (and hard to find) as a rust pinhole in a line somewhere.
Low fuel pressure/flow can also cause this. You've replaced the filter and lift pump, but did you check the output? Have you checked the "sock" on the pickup tube in the tank?
Along the same lines with the optical sensor, what fuel are you running? IE: straight diesel, dyed fuel, WVO, WMO, etc. Once again, if the fuel isn't relatively clean and clear, the sensor can have trouble "seeing" through it.
Just for some background, the optical sensor is in the IP. It's the "black thing" on top LH side of the IP with the electrical plug in it. It "looks" through the fuel and there is a disc that spins with the IP rotation in front of the sensor. The disc has slots cut in it and these slots are what the optical sensor "sees" as it looks through the fuel. The PCM uses this input to tailor timing of the injection event. The disc is spinning pretty fast and the slots are a very precise measurement, that's why anything that "impairs" the optical sensor (IE: dye, air bubbles, etc) is a problem.
