Just because your glow plug light turns on and voltage drops, it does not mean your glow plugs are working… All it takes is 1 bad plug and you have problems.
Step 1.
Check the voltage going to each glow plug using a multimeter. Should read 12+volts if your batteries are charged or 10.5 volts if you have the self regulating G60 plugs.
Step 2.
Remove all your glow plugs and check the ohms on each one with a multimeter that has a ohm buzzer. If the ohms read something stupid high or nothing at all as seen in pic 1 and you don’t get a buzz from the multimeter, you have a bad glow plug. If your Ohms are constant and show about 1.2 or .002 to 1.5 or .005 and buzzer goes off on multimeter, your plug is good as seen in pic 2.
After verifying your plugs are getting the proper voltage and are working, go next step.
Step 3.
Install a clear fuel hose going from the injection pump return nipple and the other end on the hard line return nipple (Pic 3). Verify fuel is going through and there is no air bubbles. This also verifies that the injection pump internal check valve/filter built into the IP return line nipple is not clogged. (Pic 4,5,6 pending model number)
After verifying you are getting fuel from the injection pump and there is no air in the line, go to the next step.
Step 4.
Since you have your glow plugs out, crank the motor over until fuel starts coming out of the glow plug holes. This is the best way to prime your fuel system after changing injectors/injection pump/etc. If fuel does not come out of any holes then most likely your injection pump is toast, optical sensor, ip not getting the proper voltage, pmd or your lift pump is toast or your fuel filter is clogged. Could be a hand full of issues. If fuel comes out of most of the glow plug holes but not 1 or 2, then you will know what injector/s to replace.
After each step is complete, please update us and if you still have not found your problem we will go on to the next steps which are more advanced.
