sharbour
Registered Member
Has anyone successfully done this? At first glance, it looks easy since the 6.2 was a factory option. However, it looks like there is no way to fit the 6.5 turbo exhaust manifolds without major interference from the frame rails and A/C box, according to some posters. My goal is to use as many factory parts as possible. I'm gathering info, this will be my winter project next year.
The donor is a 1993 Chevrolet K3500 longbed. It has the mechanical injected 6.5 TD, NV4500/BW4401 drivers side drop transfer case and 4.56 gears with 31" tires. Runs and shifts like a top, same power as my 350TBI at half the RPM, but almost double the mileage.
The transplantee is a 1991 K5 Blazer, 350TBI with SM465/NV241 and 4.88 gears with 35" tires and a 6" all spring lift front, 2" spring/4" shackle flip kit back.
What's the most straightforward way to do this? I haven't been able to find much info about this type of conversion without other major mods. I want to keep the body/chassis changes to a minimum if at all possible.
Will the exhaust manifolds fit? If not, should I use 6.2 manifolds with a banks turbo piping kit? Will any 6.2 manifolds work, or should I get a particular year? Can I use the the GM3 turbo with the banks piping? Would it be easier to just make a custom piping set for the GM3?
I'm pretty sure the transmission will be fairly easy to mount in, but I'm less sure about the NV241, I'll need it for the passenger drop. Will it bolt up? Will it need a new input shaft? The output shaft has already been changed to a fixed yoke.
It looks like the drive shafts will probably have to be custom length, no big deal.
Where can I find a factory 4000 rpm diesel tach for the Blazer? Did they use them on the military 6.2 trucks/blazers?
Thanks guys, any info would be appreciated!
Sean Harbour
West Linn, Oregon
Sean Harbour
West Linn, Oregon
'Course, that's assuming a guy was using the CS series alternator . . .
The nice thing about using an ESS vs the alternator is that the circuit doesn't require nearly the amount of electrical protection. The Alternator can make all sorts of spikes in voltage, which most basic electronics don't like so much. Also, changes in pulley sizes anywhere will throw the tach right out, and requires some degree of calibration right off the start. That said, if a guy were to grab a tach from a 90s diesel, and trace the wiring around a bit, I bet you could find a GM-built module somewhere in the mess of wiring which could be adapted to an older tachometer
How hard would it be to wire it in to an older style cruise control stalk on the '91 K5 steering column? This is going to be a dual purpose rig, and cruise control for those 12 hour freeway jaunts would be really nice.
