crashandburn
My 96 Burb has a strange problem.... I have a fuel leak somewhere on the passenger side of the engine. Of course it is directly behind the turbo. So today I pulled it apart, and replaced a couple of the rubber lines that go from injector to injector, and also a glow plug was just a little loose. I put it back together, fired it up, let it run for half an hour, not a drop of fuel on the ground. I moved the truck, and the leak is back.
Any ideas???
It used to leak just once in a while, but now it's almost all the time, and sometimes it's bad.
Any ideas???
