urbex
Went to check out a '96 K2500 with the 6.5 turbo diesel last night. One of the issues I noted was that the vacuum line to the turbo was missing. The rubber connector was on the hard line on top of the turbo, but the rest was no where to be found. The vacuum pot is holding vacuum OK (pushed it up by hand, blocked vacuum port with finger, vacuum pot held position). Granted, I didn't spend a huge amount of time trying to track this down during the inspection, or attempt to repair the truck on site before making an offer on it, lol.
Test drive showed little power in the motor, and flooring the throttle resulted in rolling coal every time.
Obviously the black smoke is the result of over fueling, presumably due to the wastegate now being wide open at all times? Wastegate being open would also explain lack of power, due to zero boost being built.
I just want to make sure I'm understanding the operation of this turbo/wastegate arrangement, and verify my assumptions to be generally correct, before potentially buying myself in to a major can of unexpected worms, lol. I'm familiar with turbocharger systems in general, have been through several turbocharged cars and the Banks on my 7.3, but am used to systems that work off of boost pressure to control the wastegate, not vacuum.
