jp0863
my plan is to use a 6 in lift on my suburban project, with 6 "'s will i need to modify the drivelines?
really?? Maybe it's the different brand liftI beg to differ on that one. My buddy runs a 6" lift on his 'burb, and I'm running 5" lift on a longbed, both with stock d-shafts. No, netiher one of us has had a d-shaft pull out on the trail.![]()
Or they may have sent him the wrong one. I've heard it sat up higher than any 6" lift they had seen.
Ok so i was wrong. I'll mark that on the calendar![]()
Did it come out??
I'd agree a K5 would have d-shaft problems, but yeah, Carl's (El Martillo on here) '87 'burb is 6" springs up front and 4" flip w/ 3" block in the rear with no problem. Then he smashed the rear shaft on some rocks.![]()
No, he was just using it for a rock-slider, and it got a little dented.Did it come out??
OK, a LOT dented. He had it retubed and is still using it.I seeNo, he was just using it for a rock-slider, and it got a little dented.OK, a LOT dented. He had it retubed and is still using it.
Which did he have to lengthen, the front? Some might have issues with the front due to a hort trans/t-case combo like my K20 with th350/np205. The front on mine was a little short when I put in 6" springs, but I just unscrewed the seal cap on the slipyoke. It still didn't pull apart on the trail. The rears are fine due to the long wheelbase making a smaller angle change on the d-shaft. Blazers get a lot of angle change on the rear d-shaft when lifted, resulting in a bigger change in d-shaft length.Ok so what's the big difference between a sub and say a regular truck blazer than?? I know a longbed a friend of mine had he had to have his lengthened
I've never ran more than 4" so i wouldn't know. besides the longbed i bought
pretty sure he got both. Maybe the rear wasn't necessary but he didn't want to change how much splines was holdingWhich did he have to lengthen, the front? Some might have issues with the front due to a hort trans/t-case combo like my K20 with th350/np205. The front on mine was a little short when I put in 6" springs, but I just unscrewed the seal cap on the slipyoke. It still didn't pull apart on the trail. The rears are fine due to the long wheelbase making a smaller angle change on the d-shaft. Blazers get a lot of angle change on the rear d-shaft when lifted, resulting in a bigger change in d-shaft length.
