6" lift Will I need new drieshafts
WJACKSON11X
Madison,GA
About to order lift/shackle flip from ORD. was leaning towards 4" with 36's . If I decide to go 6" will I have to get new driveshafts.
Every vehicle is different but with a 6" lift attention to the shafts is usually required.
Do you plan on lots of fender trimming? I'm running 8" lift with 35's and i rub the backside of my front fenders all the time but i'm not trimmed "yet".
A friend of mine has a 4" skyjacker all spring lift with 36's with minor fender trimming and he says he doesnt rub. I originally was going with 35's but he talked me into running 36's
you may need longer shafts even with a 4 inch. i eventually pulled my drive shaft apart casue it was too short with a 4in lift.
i had a 4 and 35's on my old 78 k5...
Some lady cut me off on a corner (double turn lane) and i had to lock teh back up... rear drive shaft popped out... middle of traffic...
You'll need to give that rear shaft some attention...
I ordered everything fo r my lift today, spent over a $1,000.00 with ORD. Thanks for the input. Ill post some pics when im done.:DOh yeah, I went with the 4"
