6 lug 10 bolts and polished aluminum wheels in VA
marine_enlisted
Stafford, VA
I am going 1 ton in about 2 weeks and moving to Minnesota a week later. I don't want to drag these along with me.
1986 10 bolt front and rear 3.42 gears, gov lock in rear, front open, warn lockouts, Tuff Country 4" steering arm, 7500 miles on tie rod ends, front wheel bearings, front brakes, rotors, calipers, hoses, and fluid in both, rear brakes look good, parking brake cable are good and will come with.
Everything is in good working order, they will come with u-bolts for a 4" lift.
$275.00
Also have a set of 6 lug 15 X 10 polished aluminum Eagle Stone Crusher look a like wheels with the imitation beadlock, center caps, and chrome lugnuts and cool flush mounted valve stems.
$300+ shipping
I won't be able to part with these for a week when my swap is done.
I can meet you between Virginia and Minnesota sometime between the 25th and 29th of May.
