CUCV2
5/4 ton fun
These are in my 91 K5 now so they are a direct bolt in.
The rear axle came out of a early 90s 2wd six lug 3/4 ton. It has new DIY4X spring mounts that allow the axle to be in the stock location or moved back 1.5". Shock mounts are for a stock K5.
The front axle is the stock 30 spline 10 bolt from the 91 K5. Both axles have 3.42s and are in good working order.
Just trying to break even on the swap. $450 for both.
Pics of the axles and swap are here;
http://coloradok5.com/forums/showthread.php?t=284568
