6 Mpg On Stock Blazer
SUBFAN said:
Bad odometer???? :rolleyes:
Yeah, that's 6.2 diesel range. Take MPG readings with a grain of salt, more often than not the speedometer readings are not calibrated for tires and gear changes.
You aren't getting 20MPG out of a gas K5 with 38" tires, sorry.
Keep the truck stock, make sure it's in good tune, drive about 50MPH on perfectly flat ground in cool weather for a long distance, and you can achieve 18MPG with a 350.
sorry to hijack but what if any mods do you have to get 18mpg's
Stock TBI 350 with:
Headers
exhaust
K&N filter
injector spacer
Open plentium TB spacer.
Velocity stack
DUI dyna mod distributor module
MSD coil
Good 8mm wires.
plugs gapped at .048
Adjustable FPR set at 14 PSI
Electric adjustable MAP sensor. I can lean out the fuel mixture for economy or richen it up for performance with a switch in the cab.
Timing set at 4*
Keep the tires properly aired up.
Change all fluids regularly.
I am prolly one of the few people on this board that is very pleased with the gas milage my K5 gets. I have never complained about it. I use it for a DD when I get tired of driving my Mustang and want a change.
