6" spring all around... ?'s
stockk5
Cromwell, CT
Well my bro wants to know if we can install his super lift 6" kit.. full springs w/ out having to get longer drive shafts... is it possible? i keep finding mixed answers...
I have been wondering the same thing. I know you CAN because I just test drove an 80 Blazer with a 6" Superlift and factory shafts. That said it did seem to have a bit of vibration. And what about off road?
I have some rear 5.5" SkyJacker springs that have the hole drilled about an inch forward of the normal spot, so no driveshaft mods were necessary on a K5. It really depends on the vehicle; almost all are different.
fireplug said:
Why would it differ from blazer to blazer?
yeah im kinda confused on that one...... im talking just bolt in a regular 6" spring into the exact same spot as the old spring.. will a new driveshaft be needed front/rear...
I have an 86 chevy longbed and a few years ago I put a 6in. lift on it. I installed 6 in. skyjackers in the front and 5.5in. blocks in the rear..the rear shaft was fine, the front shaft worked but I had it lengenthened a little anyways because offroad it would come apart. Hope that helps.
I don't know for sure, but that's why you get conflicting answers when you search. Some trucks need longer shafts and others don't, especially with 6" lifts, it's real borderline. The transmission/t-case combo can affect this also because they are different lengths. And the way the spring is manufactured will vary between brands.
ah ok i gotcha... well 700r and 208... dont know if anyone knows if this is one of the longer ones? its just a big deal cuz thats an extra lotta money he doesnt have to lift his truck.. as well as mine pretty soon..
I have a six inch spring lift with 35's and I have had no problem at all. No vibes, no breakage. D44, 14ff, 350, sm465, np208 and stock shafts.
another thing to remember is that if your truck is converted to 3/4ton the 14 bolt will make up some driveshaft length because of the longer pinion. not much but every little bit helps
hey man dont u have a longer bed pick up though? or is a shortbed pick up the same length as a blazer? thats gonna be my exact set up for axles...
i have the 700 and 208 combo with 6 inches of lift. i have stock driveshafts.i have a little vibration at lower speeds but thats it. no problems off road so far.
oh man... i dont know how u guys do this....at this rate my truck cant grow up until 2007.....
I did 6" skyjacker springs front and rear on my 91 K5.
Had to drop the transfer case and put angled spacers under the front n rear springs. Other than that every thing fit fine with no mods to shafts
realllly? haha i like this glimmer of hope thing, i guess basically its a crap shoot and jsut gonna have to try it? what degree shims did you use?
They may work for street use, but if you flex the suspension, they more than likely be to short.
