60 question..
stockk5
Cromwell, CT
This is a really newbie simple question.. but i cant remember which way the lil slider spring goes onto the 60 caliper where the bolt is. Thanks guys!
They tap in from the out side of the truck toward the center of the truck. Does this answer your ??
well kinda, i know that it slides in just aint sure of wat way to put the lil spring ontop of the slider piece. How it has a slight curve to it and then the lil bent tabs on either end. Does the curve go upwards toward the caliper or down to the ground? i know this is difficult to explain online. so thanks for trying to understand!
You put the spring on top of the slide, with the curved middle pointing up and the little tabs down over each end of the slide. Then tap the slide in.
Once you actually go to do it, it will make perfect sense as that is the only way you can reasonably get the spring in.
I think he meant "with the curved middle pointing DOWN" or 'smiling' at you.
i put them on and they seemed to work w/ them "smiling" at me, thanks guys
