This is a really newbie simple question.. but i cant remember which way the lil slider spring goes onto the 60 caliper where the bolt is. Thanks guys!
6.2Blazer said:You put the spring on top of the slide, with the curved middle pointing up and the little tabs down over each end of the slide. Then tap the slide in.
Mudstud said:I think he meant "with the curved middle pointing DOWN" or 'smiling' at you.
