Blazin'4x4
Finally got them on and gained apprx 7" of lift above my old height! Thats no good! I originally had 6" lift 52's on my Blazer with 2"BL. 8" total. I wanted the same lift height with 64,s and ended up with an extra 7".
I got this number from measuring from the ground to the frame before and after 31" to 38".
The springs I put on are eazyride 3" lift 64's, 2" shackle flip, and 6" shackles. Totaling 11". Subtract the shackle angle 2"-3" and the body lift" and it should even out or be close to even, correct. Nope. Heres some pics if they help. Lemme know what you think....
( I hate bein a knuckle head!)
I got this number from measuring from the ground to the frame before and after 31" to 38".The springs I put on are eazyride 3" lift 64's, 2" shackle flip, and 6" shackles. Totaling 11". Subtract the shackle angle 2"-3" and the body lift" and it should even out or be close to even, correct. Nope. Heres some pics if they help. Lemme know what you think....
