Got the oem plugged in and wired w the MSD coil.
Filled up the bowls, squirted a good shot down the carb and cranked, fired, stall, repeat.
It just wanted some RPM and more fuel. Ran for a few seconds, and when it died I stopped the video then adjusted the idle up and restarted it and ran about 30 seconds at probably 2500rpm. Heads and block were warm. After several minutes off they were quite warm!
Happy to hear it make some noise!
Thanks
@folkenheath for all the assistance with the parts and pre assembly work.
