Well its been a few minutes.
The last couple weeks have had me concerned. After flipping the frame and deciding to cut out the siderails, I started measuring to keep from screwing this up. BUTTTT, it seems things are a bit wonky. Ive got twist, and out of square measurements going on here. Factory tolerances on these early frames had a big window from what I read, but I cant believe this couldn’t be much better. These bodies were glued together in a standard jig setup and were considered ready for assembly to the frames. The frames had more tolerance issues and were measured using a standard body to frame jig and shims were made to fit each location on the frames. The frames had marks added to let the assembly workers know how many to add at each mount.
