Today we (Kert) made big progress.
New frame rail sections (w inner splice sections). And new bottom of front crossmember.
frame welded and anchored in place before measurements are noted and cutting begins.
Plasma makes quick work of the rough cuts
Bluetooth frame rails in place!
Just joking…measuring and fitting the frame rails
Rear crossmember roughed in
Sizing up frame rail halves, getting the correct width before tacking together
Fitting the splice inserts
Tacking new rails in place
Welding new rails in place
Finish welding halves together
Seam welding
Rear crossmember welding
Plug welded inserts
It may look out of place now but in the end it will look better
straightness
Now to replace the front crossmember bottom plate
Cutting out the old spot welded in place plate
New plate welded in
Adding new lower A arm brackets
Finished…need to drill a few holes for the A arm bolts yet.
