Figured it might help some folks if we had some info gathered in one place - also because there is so much misinformation out on the World Wide Web.
This thread is not meant to cover every single detail of these transmissions but rather some basic identification information that can be trusted.
As time permits I hope to have other identification resource threads to include auto transmissions, axles, differentials, adapters, transfer cases, CV-joints, crossmembers & braces - just to make searching a little easier.
These are pictures that I have gathered over the years and most are from the web and some are from CK5 so y'all might recognize a few of them as we go along.
Remember this only pertains to K/V-series GM trucks from 67~87/91 — and to keep it simple the “V” applications are referred to as “K”.
These are the four manual transmissions used in 4WD K series trucks from 1967~1991.
SM-420 Muncie 4-spd
1947~1967
Input torque rating:
Overall length -
Type of lubricants:
Weight -
Input shaft 1-1/8” 10-spline
Output shaft 10-spline
1st gear - 7.05:1
2nd gear - 3.57:1
3rd gear - 1.70:1
4th gear - 1:1
Reverse - 6.78:1
Shift pattern:
SM-465 (CH-465) RPO M20
Muncie 4-spd
1968~1991
Output shaft:
68~80 K5,10,20 10-spline
81~91 K5,10,20 32-spline
77~84 K30 10-spline
85~91 K30 32-spline
1st gear - 6.55:1
2nd gear - 3.58:1
3rd gear - 1.70:1
4th gear - 1:1
Reverse - 6.09:1
Shift pattern:
Note: The SM465 ( CH465 ) was used in the 88~91 GMT400 trucks as well but had a different aluminum top cover with the shifter tower moved to the rear to accommodate the new truck interior design.
SM-330 H.D. RPO ZW4
Muncie 3-spd
67~81
Output shaft 27-spline
1st gear 3.17:1
2nd gear 1.75:1
3rd gear 1:1
Reverse 3.76:1
Shift pattern:
NP-440 RPO MY6
New Process
4-spd O/D
Note: Based off of the NP833 ( same 4-spd used in MOPAR 440-6 & 426-HEMI’s ) but modified gear ratios with an overdrive for GM trucks made with a cast iron case instead of aluminum.
81~87
1st gear - 3.09:1
2nd gear - 1.67:1
3rd gear - 1:1
4th gear - .73:1 O/D
Reverse - 3:1
Shift pattern:
Please add to the discussion of these transmissions of this time frame so we all can benefit and collaborate and collect good accurate data together.
Hope this is help for any fellow CK5’r in need and helps to keep CK5 a reliable resource.
Tom
SM-420 Muncie 4-spd
1947~1967
Overall length -
Type of lubricants:
Weight -
1st gear - 7.05:1
2nd gear - 3.57:1
3rd gear - 1.70:1
4th gear - 1:1
Reverse - 6.78:1
Shift pattern:
Muncie 4-spd
1968~1991
Output shaft:
77~84 K30 10-spline
85~91 K30 32-spline
1st gear - 6.55:1
2nd gear - 3.58:1
3rd gear - 1.70:1
4th gear - 1:1
Reverse - 6.09:1
Shift pattern:
SM-330 H.D. RPO ZW4
Muncie 3-spd
67~81
1st gear 3.17:1
2nd gear 1.75:1
3rd gear 1:1
Reverse 3.76:1
Shift pattern:
NP-440 RPO MY6
New Process
4-spd O/D
81~87
1st gear - 3.09:1
2nd gear - 1.67:1
3rd gear - 1:1
Reverse - 3:1
Shift pattern:
Tom
