Well Ive posted a couple pic's here and there. Figured might as well make up a build thread. This will be a thread Ill slowly update to the current place Im at with the car
As far as my plans are for the car, its being built a driver. Not quite a pro touring style. I want something that can corner well and can run the highway comfortably.
1967 Pontiac Beaumont Custom, bought this thing for a song/dance in the spring of 2010. It had been sitting about 8-10 years before I got it, ran once in that time. We towed it down the street, put a battery in/fuel/water checked the fluids and drove it home a couple hours later.
It had a stock 70's 350/turbo 350 in place of the 6 cyl/Glide and 8.2 rear with 3.08 gears. Spent the first summer fixing PO hack and getting it driveable. Ran it how it was for the year, but the motor smoked like a typical sbc and was underpowered. So out it came that fall, and we built up a L31 Vortec 383. Cant remember the exact spec's, but its approx 400 horse/ 450 ft lbs according to a computer dyno. Got the trans rebuilt, shift kit, 3K stall. Rear was on its way out, so I got another rebuilt with 3.73 gears/lockright. Blew the lockright up this past spring, so I put an eaton in it and havent looked back.
Anywho, enough typing and onto the pic's:
day I brought it home, complete with centerlines and exhaust pipe coil spacers out back :haha. Almost forgot, it had the Dunlop GT qualifiers which havent been around for years
the motor in all its glory:
Stripped the interior out, it was all sun burnt. The floor was overall pretty solid other than where seam is on the front of the floor pan. I was able to patch the one side, but the drivers needed a patch panel.
the worst of it:
the rear body mounts in the trunk that were properly fixed
I ended up having to cut all the body mount bolts, I lifted the body up off the frame for ease of work on it.
the one rear body mount had this welded on the frame, appears the frames been straightened and fish plated.
So I made one up to match the other:
From than on I put new bushings in, bolted the body down. Guess I never mentioned that I did all this in my gravel driveway?
Back on all fours, rear coil spacers removed. Put a set of Cooper Cobra 265/50/15's on the back and 215/70/15s up front.
I should have an update later tonight or perhaps wed.
the worst of it:
