i haven't driven it in 6+ months and i want a bike, so it's for sale.
it started as an Axial SCX10 kit, it's now a fully custom built scaler. all the tube work is 3/16" brake tubing, notched and brazed together. ive got probably 40hrs into this rig. the front and rear bumpers are solid rod. it has head/tail lights mounted on the body but the light kit is not installed, i'll throw it in the box. the winch needs a cable and hook, otherwise the rig id ready to go.
specs:
SCX10 chassis with custom cage, shock hoops, bumpers and boatsides
SCX10 axles
Hand bros chassis mounted steering kit
lengthened rear links (5/16" delrin rod)
R2J customs rear 4 link truss
losi 4" shocks
Mayhem Engineering "trail shooter" beadlocks
custom made Ironworks 4.5" flatiron tires
35t motor
mamba max ESC
spektrum Rx
hitec 645mg winch servo
hitec 5645 steer servo
head/tail light buckets mounted in the body
head/tail/rock light LED kit
spare tire mounted on the chassis, scale fuel tank with filler neck for weight bias (7oz in there right now)
interior out of a proline blazer body mounted to the chassis
mesh net over the cab
scale diesel exhaust stack mounted to the chassis behind pass seat
i'm sure im forgetting stuff...
its being sold basically RTR, with all electronics and 4 1500mah 3s lipo batteries, all you need is a radio and a charger.
SOLD!
specs:
SCX10 axles
losi 4" shocks
35t motor
mamba max ESC
spektrum Rx
SOLD!
