zombie1969
Hay everybody.Im having a deceloration noise that sounds as though it comming from the tcas or rear of trans.I came across an old post here from 8 years ago with no end result posted and as yet I do not have permition to post a link to it.It.I was also having a shift grinding when going from 2h to 4h so I tore the case down and found the last person failed to install the main sincro and related parts.6 parts total missing.Also the planet gear was damaged beyond use where it rides in the annulus bushing.I purchased a used unit and was able to get all the parts nessassary to compleet the rebuild with the exception of the bushing which I got new.I have years of dealer experiance rebuilding tcase units and Im confident its corect but no experiance with lifted trucks.This is only my second truck Ive had and the first was all stock s15 jimmy not counting the 87 parts truck used for the drivetrain in my current full size 84 jimmy.The tcase drop down spacers are out of the shortbed parts truck and Im thinking I need more of a drop but not how much.BTW I can recreate the noise with the rear wheels jacked up and with the tcase in newtral no noise so I thinking its still tcase back problem.Any simular experiances with this problem are invited.Thanks Gary.
