looking for a set of 4 wheel adapters to go from 6x5.5 to 8x6.5
I’ve been down that road… almost killed a nunTrying to kill yourself?
One of mine sheared the bolts apart with the 40’s on it in under 2 yrs.was going to put them on my Toyota buggy so I could run 8 lugs on all the rigs
They were loctited, torqued, and well maintained. So be aware.
I am still considering the Redhill option but I would be plugging the old holes with weldI looked into something like this from a "redrill" the hub for the new pattern before. The issue is the patterns put the lugs too close together to the point of not having enough material to remain structurally sufficient. I would not recommend them as a mechanical engineer.
In that case, I don't see an issue. The welded holes lose some strength, but not as severe as two holes close together.I am still considering the Redhill option but I would be plugging the old holes with weld
My thought was to cut the stud flush and weld it around better than filling the whole..what are your thoughts?In that case, I don't see an issue. The welded holes lose some strength, but not as severe as two holes close together.
I was suggesting shaving both sides.You will still have the head on the back side to deal with holding the drum/rotor. That won't work. I would insert a piece of copper rod halfway into the hole, weld up one side. Then, remove the copper and weld up the other side.
Swap full widths on the toyota, run 8 lugs without spacers. Problem solved and safer!![]()
A rig for everyday, and rest on the sabbath!actually after reflection probably just going to sell this one as well. I can't take but one at a time to wheel. I'm getting older and want to enjoy life more. right now I am looking at keeping 6 wheeling rigs but that may change tomorrow
