70 C20 gmc Disc swap???
ben427
Waverley, Nova Scotia
Searched and didnt find anything. I just got ahold of a 70 GMC 3/4 ton 2WD with a 402 /forums/images/graemlins/peace.gif and a 465 tranny. The darn thing is drums all around. I have a couple old 85 C20s juked and was wondering if i couuld use the knuckles, spindles, rotors, and caliper without much work. In other words wil the newer knuckle bolt up the the older suspension ok???
yes 63-87 5 through 30 series will swap, use the centerlink bar and such from donor truck and get new balljoints for donor truck year and model, you will have to re route brake lines just like you would have to on a 5 or 10 series too when swapping 73-up onto a 72 older
personally i would swap the entire engine cradle suspension assembly over
Thanks!thats what i thought. I would do that but the only good thing on the whole parts truck is the knucles and spindles, the rest is hashed big time.
even the entire cradle is damaged unuseable ?
preferably you would want to swap entire cradle assembly to save yourself alot of disassembly and balljoints swapping and aligment problems and so forth, then all you would have to do is drill a coupe holes and re route the hoses and hook everything up and done
to convert an 8 lug truck to disc front you need 20 or 30 series spindles rotors calipers TRE's centerlink and lines hoses and thats about it, 20 and 30 series all same cqlipers and such unless different thicnkess rotors in which some did have thicker on higher GVW, but not that common, not as common as in 10 series trucks from 1" to 1.25" rotors
good luck
oh, gotcha, know all about that hehe
happy conversion/swap, you can email me or find me on yahoo messenger fastr68 is me on there i will answer any questions regarding this, and i have a NAPA chassis parts catalog that i can get you numbers of parts and compare to see what you really need to swap for sure from the 70-older to the 71-up setup as far as TRE's idler arm and pitman arm and ball joints and such go
R
