Finished up the wiring for the steps last weekend. Left the trigger wires a little long for now, will trim them when the harness goes in for good later on (same for the courtesy light wires).
Installed the Trique door latches today. Went fairly smooth. Had a little issue with the lock rod on the first side. Bent it like they wanted and couldn't get it to fit at all. Ended up getting it through the top hole and working it into shape from there. The other side I was going to do the same thing but it didn't even need to be bent.
I spent quite a bit of time fitting my doors with the factory latches. In my opinion they opend/closed great and I didn't think there would be much improvement. I will say that I was 100% wrong on that. You don't notice it much with the factory parts, but because of their design, they rattle a little bit when you shut them. Even when they are closed there is a little bit of play. Now, they close so much better and positively. Even sounds better when closing. If you have a 67-72, you need these. Absolutely worth every penny.
I'm 99% sure that these are the set of doors I'm going to keep on here (I have another good set of truck doors too). I only bolted the latches in when I had planned on welding them. I'll probably weld them in once I get to body work on the doors an am committed to a set.
Truck budget took a little hit recently. Had to go to the ER a month or so ago. Went in for severe abdominal pain and found out I had a kidney stone. Bills are starting to roll in from that. So far it's up to almost 7k. I think I've gotten all of them now and paid. I had wanted this to be on the road sometime this summer, still going to try for that but I'm not going to rush it or cut corners to do it.
