Been slacking on the updates with this.
Last weekend I mounted the seats and harnesses. Bar for the shoulder belts will need to change as it's too low right now. I'm going to have to track down a bender and some more tube to correct that. Harnesses are PRP 4 point.
Used the later style K5 bases. Originally they had the seats too high. Cut one inch off the bottom and welded some 2"x1/4" strap to the bottoms for mounting. Also slid them towards the center a little.
Along with the seats I closed out the transmission tunnel and mounted the transfer case shifter and center counsel. The tunnel is only temporary, it's got some dents and rubbery undercoating that is a pain to remove. Looking for a nice used one. That one will get LizardSkin on the bottom and Raptor on top.
Bumpstops were next on the list. I believe these are from a GMT800. Because of how I ran the exhaust I couldn't mount them in the stock location under the frame rail. Took some 4x4 box tubing, cut it diagonally.
Mounted above the spring plate.
I'm not sure if they are mounted too low or not. I expect them to compress some. I can always trim them a little as well.
One of the must do things I've been putting off was clearance the crossmember above the driveshaft. Sectioned a piece of 6" pipe into it.
Got some wheels for the paddles. 17x9 Visions in a gunmetal finish.
Bought 4 of them. Idea is once I get new tires on the MT wheels I'll use the best two for the front on these wheels. Also wanted 4 because it's easier to sell a full set rather than just two.
