Wasn't out of town all week for work like I normally am so I was able to get the transmission tunnel knocked out.
Could have patched mine, and I probably should have. The new one doesn't fit as well as the factory one does. It's slightly narrower and curved differently.
Coated the bottom with the last little bit of LizardSkin I had on hand. Top got some Raptor liner. Only had one bottle left and it already started to set up by the time I got around to the second coat. Wasn't spraying very well, even if I cranked the pressure up some.
Used a shifter boot and transfer case bezel from a square body. Tried moving the t-case shifter as far back as I could. Still on the look out for something different for that.
Painted the fenders this afternoon. Depending on how they look I might hang them tomorrow and sand/polish right on the truck.
Eventually I'd like to find a better set. Mine aren't horrible but I didn't spend anytime working the insides, mainly the "fang" area. I cleaned up the rust and treated it, but there was enough there that I didn't want to get into cutting it out and putting new in. The outside is straight and rust free which is all I was concerned with at this time.
