fatdog
Registered Member
I have decided to do this swap into my 72 k5, and I'm hoping some people here who have done this can give me some specifics/tips on how to go about it
. I'll probably try to get the trans/transfer case combo from a 87?-91 blazer or sub or separately if need be or if that would be a better way to go because the 700 might just be a core anyway. What I was wondering is what should I be looking for specifically ie: elec/manual speedo, "K" case trans. Also should I get the cross member or use mine? I would like to leave the engine in the factory position so....if I did will I be looking at driveline mods with the sye kit? Is this combo shorter/longer than the 350/205 I now have? Should I use the factory tansfercase shifter? Future plans include the install of TPI as well as cc. Would the elec speedo be better for aftermarket cc? The reason for doing this is this K5 is my dd and from what I've read here this would make it nicer on and off road with the addition of od and the lower tc gearing. Thanks for any info.
Rob
. I'll probably try to get the trans/transfer case combo from a 87?-91 blazer or sub or separately if need be or if that would be a better way to go because the 700 might just be a core anyway. What I was wondering is what should I be looking for specifically ie: elec/manual speedo, "K" case trans. Also should I get the cross member or use mine? I would like to leave the engine in the factory position so....if I did will I be looking at driveline mods with the sye kit? Is this combo shorter/longer than the 350/205 I now have? Should I use the factory tansfercase shifter? Future plans include the install of TPI as well as cc. Would the elec speedo be better for aftermarket cc? The reason for doing this is this K5 is my dd and from what I've read here this would make it nicer on and off road with the addition of od and the lower tc gearing. Thanks for any info.Rob
From the info I've read so far that seems like a reasonable way to go. The fI will be a first for me so I've got a bunch to learn, but I'm wanting to do it to make the k5 a nicer dd and I think the FI would be a cool project for me to learn about.
