This transmission may be original to the truck. It went out in 2000 with a failed torque converter and chewed up front planetary. That was my first time inside an automatic transmission, which I complicated by doing a bunch of upgrades. I used a B&M SuperTransKit, put in a newer pump, upgraded the forward sprag and ended up with a Corvette servo because the thing wouldn't shift right without it. I remember modifying some of the 4th clutch plates to fit the little aftermarket release springs and feeling like I was in uncharted waters.
To make a long story short, I had decades of solid performance, then this year it started to stay stuck in 1st gear. Metal in the oil was making the T/V stick. I hoped it would let me lead the overland trip in August as planned, but I sadly took this vehicle out after the 1st day.
After teardown, the failure mode is thrust washers.
At first I thought the top one was a washer, but there's no such part in any diagrams. It turns out it's supposed to be part of a Torrington assembly, which I scored at the local driveline shop.
What has me stumped right now is the amount of brass in the filter. All of the bushings look good, so I have to believe it's a brass thrust washer. It's too thick to be from bushings and all springs in the sprag are intact. I've got to go through everything and figure out which one went AWOL.
. I always liked how it would downshift as needed in the dunes, it will go back to 1st without stopping and it offers great compression braking for descents, so I guess if it's not broken...of course it is, so I will, but you get the idea.
