Quick Question. Which line, top or bottom coming from the trans side is the fluid out to radiator? My new Monster Trans built 700R will be here tomorrow and I'm putting in a cooler. I have read that the fluid should go from the trans to the bottom of the top of the internal cooler in the radiator then from the bottom outlet to the cooler. From the external cooler back to the return on the trans. Does that sound right? What is the consensus?
