Artemis Entreri
Thanks, how does the old ujoint come out so I can put this one in? I've never noticed.
4x4high:
1310 is what most 4x4 1/2 ton u joints are. I believe they are 3"? across and 1 1/16" cap. Unless He's got 5 lug 1/2 ton rear and/or driveline, he wont need a 1330.
1350's would be correct for the 14 bolt, with a 3 1/4"? lockup across and a 1 3/16" cap
A 1330 isnt a conversion joint, it has a cap size of a 1310, but the width of a 1350. It is equal on all 4 corners. It also used on the 5 lug rears at the diff.
The above holds true in SPICER parts, cant imagine why it would be different in other apps.
Oops, i meant 3R joint for his shaft and 1350 size for the 14ff
I set the driveline in a vise to hold it, pull the clips out and use a junk socket to beat it out of there.
Isnt a 3R joint the replacement for the plastic injection CV shaft joint in the front driveline? Arent they a inner lockup style?
Any idea why the ujoint in the front doesnt fit side to side?
yeah, i hate it when those egg yolks get on there and everywhere, nasty stuff.![]()
