Well the constant pressure valve body does more than eliminate the TV cable. If that was all it did it wouldnt be worth it. Its right there in the name "constant pressure" Thats ALMOST a manual valve body effectively, meaning whatever gear you put it in its going in that gear and staying there. Basicaly it would make it shift the same as a th350 or th400
Ever drive a stock 700r4 and drop it down into first and floor it? It WILL NOT stay in first until the trans blows up. It will shift itself into second when the pressure peaks. Its a function from the factory, that was supposed to aid in
This would come in handy in any situation you need the trans to stay in the gear you put it in. OR downshifting. Likewize going 70mph and you drop the shifter down to second gear, nothing will happen in a stock 700r4 until the pressure drops down.
Technicaly GM claimed a 700r4 was designed to down shift while towing. You are supposed to be able to drop the shifter down to 1st gear at any speed and as you apply the brakes and slow down enough to be safe the trans is supposed to downshift at the correct time.
Wouldnt it be great if they actualy worked the way they was designed to?
WARNING! I do not sugest anyone runs out and tries this. I honestly belive that their plans for the 700r4 failed. This was explained to me by a GM factory trained transmission man and he also said it does not work like they intended.
I have herd of some of them working this way but it seams a hit and moss situation, Some do and some dont.
Before anyone asks me to get more techinical this was the way it was explained to me. I AM NOT a transmission expert.
I looked into this valve body about a year ago, but I desided to have it built beefy and leave the original shift functions.
