The sock filter its made of fiberglass or plastic and has such a fine mesh that water cant pass thru it,and that can lead to intermittent fuel starvation if there is some water in the gas,many times it gets overlooked as a cause because its "out of sight--out of mind"..
If you put an additional fuel filter between the tank and fuel pump,that sometimes makes it harder for the pump to suck sufficient fuel to the carb or fuel injectors..
I'm wondering if my diesel is starving for fuel at high speeds or under acceleration due to the sock filter--it was perfectly clean when I put the used tank in a few years ago,but since then I had one fuel filter (the big water seperator spin on one on the firewall),clog completely up and leave me stranded..
I cut the filter apart and couldn't believe how much sludge and tar looking crap was in there,and rust from the filter can--cant understand how those big pieces of gunk made it past the sock filter on the sending unit..
I also wonder how much of it made it all the way to the injector pump..
..but it ran fine after a new filter was installed,until recently..thought the electric fuel pump I added that had failed was causing the fuel starving,but it still does it after by-passing it..
I may have got some dirty or watery diesel fuel..
