tomford
Hey guys,
I tried searching with out much luck. I have an 87 K5 that i swapped a rebuilt 4L60E in and it keeps cracking input shafts apparently. Figured i may as well swap it for a 4l80E. I have a 241 case now, what am i going to need for a swap? 32 spine input shaft for the transfer case. Will the trans to t case adapter work? Saw the dipstick is different, anyone have a part number? Is the shift linkage in the same spot?
Eventually I'd like to swap a 6.0 in. Just trying to do a little bit at a time, and drive it in between.
Tom
Tom
