That's a smokin deal on a NV4500. Make sure it is a NV4500 though...
http://www.motivegear.com/tech_info/tranny_guide/images/nxnv4500.jpg
NV3500...
http://www.motivegear.com/tech_info/tranny_guide/images/nxnv3500.jpg
You'll need a few other things to bolt up a NV4500. First question is is the NV4500 a 4WD version? What year is it and does it come with a Bellhousing? Is it one with an external slave, or the later internal slave? What T-case do you plan on running?
A NP241 or NP208 will bolt up to the NV4500 no problem, as long as the T-case is 32 spline. The output adaptor housing on the NV4500 has the generic 6 hole pattern.
External slave is nice, except the slave on the factory bell is on the passenger side and is prone to getting hit by the front driveshaft.
Internal slave eliminates that problem, but if/when the slave goes it'll usually take the clutch disc with it, and it's a pretty big job to replace it (vs an external slave.)
Advance Adaptors makes an aftermarket bell that puts the slave on the drivers side externally. That was the option I went with. They sell a bracket so the standard GM slave you'd find in our trucks fits.
Here is a good shot of the rear of the tranny. If the one you're being offered has a fixed yoke instead of this...then it's a 2WD tranny
Advance Adaptors bell. You can just make out the shift fork on the passenger side.
Close up of the fork and slave mount parts. The mount for the slave is for a Jeep slave which is pretty inferior to the GM piece. I don't think I have a pic of the adaptor bracket for the GM slave.
The NV4500 shifter sits about 5" farther back than a SM 465 shifter too.
one more, just cuz I'm a whore...
Aside from those issues it's the pedal hanger assembly that'll be the biggest pain. Just remove the whole steering column right away. I tried just dropping it, then I unbolted everything but didn't remove it from the truck, then I finally got smart and got it completely out of my way. once it was completely out of the way the pedal hanger swap was easy enough.
Where in BC are you? I'm just outside Vancouver...
Rene
