700r4....
79k20350
3/4 ton status
Ct
So the next project is a turbo 6.2 85 k5. im gonna be running 38's & 1 tons w/ 4.10's. really i gotta keep the od to be able to get a decent highway numbers (right around 1800) then i got thinking. isnt a major problem, w/ the 700r4 that every thing was geared way to high? i thought that was a big problem (like 308's and od) so to get the rpms we need arent we basically dooinng our trannys from the begining?:confused:
Well I'm running a 700R (behind a 6.2 w/turbo no less) spinning 38x15 with a 4.56 gear. I do have to drop out of OD alot if I'm on the highway and hit a pretty good size hill (we got HILLS) and/or if I'm not pushing 60+mph. My 35" tires worked better with my OD/gear combo.
Now with your 4.10 gear I think your right about not wanting an OD (.70).
Tire Gear Trans RPM@65
35" 4.56 .7to1 1992
38" 4.56 .7to1 1835
38" 4.56 1to1 2620
38" 4.10 1to1 2356
38" 4.10 .7to1 1650
'Could build a pretty stout TH400 with maybe enough left over to flip for the lower 1st gear-set :thinking:
http://www.4lo.com/calc/gearratio.htm
i was figuring a 38x15x16.5 radial at 70 would be 1825. pretty much wear we want to be. im still thinking of 465 though...hmmm...
