magik235
Still Alive
Are your O2 sensors heated?
Little bit of progress but nothing picture worthy. Pulled the wiring harness and picked up a harness from PSI. I talked to a buddy of mine who ran a hot rod shop for years and he said they arent really designed to go in and out especially after 10 years. The wires will crack inside the insulation and cause hell. Sounds kinda like what I have been dealing with....
I also grabbed some 2" .25 wall square tube to redo the rear bumper. The more I looked at it the more I hated the look. Going to do 2" square tube center section and some round tube out to the sides.
Also picked up a disc brake 14ff, 3.73's, an open carrier and the perches already ground off (best part). If I am going to redo the brake lines may as well swap in the axle I want. Do it once and not have to bleed them multiple times.
You however, probably started with that funky Eaton rear end right lol, so the 14b sounds like the perfect swap.
(you don't even have a reverse switch
