I was told the engine is a 454. I haven't verified the displacement beyond it being a big block. No idea what has been done with it aside from an HEI distributor, intake, headers and an edelbrock carb. It sounds like it has a camshaft in it, but the engine does not run very well. Either the carb is a turd, or the engine components are very poorly matched. It does not have a lot of power, especially down low. I am somewhat spoiled by diesel engines, but it should have a lot more torque than it does. I have no idea what engine it originally came with aside from being a V8, there is no option list anywhere I can find inside the car. I would presume it had either a 307 or a 350. I am pretty sure the big block was swapped in. The transmission is a 4 speed of some variety. I am not sure exactly what it is, but I do know that the car was originally a column shifted automatic based on how the shifter hole was cut and with an auto steering column with the shifter removed. The rear end is a 12 bolt of a yet to be determined ratio. I'm guessing it has fairly tall gearing though based on how poorly it launches. My plan right now is to install a modern 8.1L to replace the 454 with the existing 4 speed. It will be stock except I intend to use an 99-02 drive by cable PCM and a 7.4L throttle body. In the long run, I may replace the 4 speed with a Tremec Magnum 6 speed, but that'll be a while as they are big $$$ and I'll have to cut out and replace the transmission tunnel.
The car was definitely a Malibu and was cloned into an SS. It still has the sweep style instrument cluster in it. I plan to replace the dash with the SS style cluster and install some Dakota Digital gauges that will play nice with the 8.1L. I also plan to install a stock center console. Of course, it'll get a modern radio head unit that looks like a stock one but has hands free bluetooth phone support, aux outputs for an amp and some decent speakers. The cowl induction hood flapper is zip tied open and has none of the control parts. I'll likely add them in as well despite swapping in the EFI engine haha
It has a 12 bolt rear end, I'm not sure if it is posi or open. The car has aftermarket disc brakes up front and stock drums out back. I do plan to remove those butt fugly Foose wheels and rubber bands to put some nicer Cragar or stock SS style wheels on with stock sized rubber. I have no suspension mods planned at all. I plan to use it as a summer cruiser. Take it out for dinners, over to a friends house or just a nice cruise on a warm summer evening. No racing plans at all. Just a nice suble upgrade with some modern parts but more or less keeping it stock on the outside.
