71K5 - BP71K5's Just for fun build
Thanks everyone. This kinda work makes you appreciate why professional paint jobs are so expensive. The nice thing about this particular paint is that color matching is very accurate for someone like me who won't paint the exterior for a while. All of this is technically on the interior so it wouldn't even have to be an exact match to still look nice. I may farm out the exterior.
Update 07/19/2016
Took a vacation day from work today and just went for it.
Used my roll cage as a makeshift spray booth. Used a big 24" fan and a couple furnace filters to clean the air going into the fan. The intent was not to seal the surfaces from paint, but keep a nice current of air over them to help prevent bugs and dust from settling on it. Sprayed down the driveway and surrounding areas with water to help keep dust at bay as well.
First coat of PPG envirobase HP "hugger orange". This is a water based paint and is a little tougher to spray, but it drys fast and is super easy on my delicate skin. It's also what a lot of auto manufacturers are using now so I figured it should be good enough for me.
I spent days wet sanding everything that would be visible with 400 and 600 grit paper. The water base paint ends up being very thin mil thickness so it really shows any scratches that are in the primer coat. First coat drys out very matte and covers really well even with this orange. You can see what looks like a run, but isn't, but is. That's the seam sealer that I missed smoothing out. It's covered by the cowl so not too concerned.
And first coat of PPG EC530 clear. Goes down fairly nice. I was fully suited up for this stuff as its traditional solvent based clear. I also get allergic reaction to urethane so got new carbon filters for my respirator as well. No selfies of that though.
And final coat of clear.
All in all came out pretty good. I did find one run on the dash. I think it can be buffed out fairly easily after it drys. Other problem was caused by having to go from outside the truck to inside while spraying. You can see this wooden frame I used to keep the hose from running the rockers in the fresh paint, but I forgot about dust on my feet and so there's some lint and dust on the rocker on the passenger side. I'll buff that and reclear if needed.
But this gets me back to where I can reinstall the windshield and get it back into running condition for the rest of the summer.
HERO DAY!!!! :bow:
Nice job Brian, looks great.
I'm going to have to reprogram myself... I've forever thought of your 1st Gen as "the white truck" of the group. Seeing it orange is a bit of a shock (in a good way)
-G
The surest sign of a great addiction. I made that same maneuver yesterday, too.
Truly outstanding work. I refer to this thread, among a few others, as an inspiration for and a validation of the belief that, "you can do anything with a methodical approach." The quality of the product bears that out.
Notes taken.
David
That turned out great! Didn't you worry about bugs landing in the paint?
Awesome build Brian, and your paint job looks amazing s far!
Do you have a rough plan for when it will be fully painted?
Not really. If you look closely, you can see two extra holes below the windshield frame that are clearances for 1.75" tube. One of those might as well things that will eat up more time. The rest of the body needs a ton of work. Maybe by blazer bash 2018...
Update 07/28/2016
Decent start on reassembling the interior. Painted the glovebox door, shifters, trans tunnel, etc.
One item I'm disappointed in is how the bolts on the trans tunnel tear up the clear coating when their torqued down. Any paint experts know if this is a product failure, application error, coating too thick, etc? Not a huge deal, but I'd like to avoid it in case I have more of this type of paint application.
Paging @ryoken
I'm sure he knows that one....
:bow:
-G
