Update 8/16/2017:
Right after I scheduled another short family camping trip, I got my UPS notification that a 53lb box from ORD was scheduled to arrive the day after we left. So I rescheduled the delivery for yesterday and couldn't wait to open it when it arrived at 8 at night. Steven walked me through some options on the phone, offered some advise on shifters, collected some info on my k5 and had it on my doorstep in about a week ( which was a week ahead of what was promised)
Here's my new Offroad Design Magnum Underdrive box. It is super securely packed with reinforced shipping tape. No sign of trauma to the box or contents. Impressed so far.
Inside the box is a smaller box of hardware, and the magnum underdrive gear box hardware is wrapped in plastic and then spray foamed to the inside of the box. I tried to be clever by removing some foam from the top to cleanly remove it, but eventually just ripped the box open to get it out.
There's all the parts layed out. Starting from top left and moving clockwise
1. Bag of seals and gaskets
2. 4 urethane cushions
3. Giant input gear for the np205
4. Set of general instructions (and stickers!)
5. The magnum case with planetary gear and shift lever pre-installed
6. Metal brackets (wrapped in plastic) to aid in fabricating a crossmember
7. Another bag of nuts and bolts
8. A new input bearing and clips for the np205
I couldn't find a coke can to give a size reference but this shaft is huge.
First step for installation is removing the 205 input gear. To do that you need to remove the rear output shaft housing, remove the rear output shaft (and drop all the little roller bearings as the shaft comes out, don't say you weren't warned!)
Then remove the shift collar. I had to shift the fork forward to remove the collar.
Then remove the input shaft to get where you see in this picture.
Then the giant magnum shaft goes in and the included bearing gets clipped onto the shaft and holds it in place. You can see my np205 was previously setup for use with the ORD doubler and so I have my own shift brackets that I copied from ORD before I got their shifter parts.
There's the shot of the rear of the case.
Then you load up the rear output shaft with grease and put back all the roller bearings into the "female" side of the shaft. Then gently slide the rear output over the magnum shaft making sure none of those roller bearing fall out. You should have also put the shift collar back in before this step.
Then you put all the other roller bearings that fell out back into place in the rear output housing, reinstall the housing, the speedo gear spacer and speedo gear, then the seal housing and seal.
With the rear done, we prepare to install the magnum case onto the input of the np205.
You need to remove shifter plate on top and then the 6 long Allen bolts from the front of the case and then separate the case halves. ORD was thoughtful enough to design these small
notches in the case to help split it apart with a flathead screwdriver. At least that's what I used them for and hope was intended.
Case apart
Here's where I got confused. The case half needs to be bolted to the front of the 205. I siliconed a gasket in place and then positioned the case. There's a total of 8 holes in my case ( why it's called a "figure 8" np205). 5 bolts are inside the gear box. I initially installed 8 studs here but that is WRONG. The three holes near the top of the case get standard bolts with red loctite. The two lower spots get the shorter allen head bolts also with red loctite. The last three holes get longer standard 3/8" bolts that won't tighten down all the way unless you also add the big steel "chunk" meant to be used as a crossmember mount. I didn't use loctite on these three bolts yet since I'll probably remove this plate when building the crossmember. The plate also has a side benefit of stabilizing the assembly on the bench a bit.
Then the other half of the magnum case gets bolted back in place with the 6 allen head bolts and a bead of "the right stuff" between the case halves to seal it. Bolts get blue loctite. The bolts come with antiseize on them. I initially though I needed to keep it but realized using anti-sieze and loctite together is not a good combination. So I cleaned the bolts and used loctite, although looks like this bolt needed to be cleaned better.
Shifter housing also gets bolted back in place with sealant. There's a couple front view shots.
Here's the shifter mechanism as shipped. The arm can be rotated 180 degrees if needed for shifter use. I chose to do that since my triple stick shifters seem to be easier to make work in that spot.
Here's the shifter rotated. There's a couple set screws holding it in place.
And there's the final assembly with studs in place to clock the transfer case assembly close to flat. I initially used these studs to bolt the mangnum case to the 205 since that's what my original doubler used. But after reading the instructions a few times, I figured out which bolts go where and corrected it.
So now it's ready to bolt it in place on the back of the nv4500. Then I need to move the transfer case shifters back to where they were originally. Since the motor and trans moved back 3", the magnum is about 3" shorter than the doubler system, which puts the 205 back in the same spot it was originally (saving my expensive CV driveshafts) the transfer case shifters need to move forward 3" now to stay in the same hole on the trans tunnel.
So far I'm really impressed with the build quality, sheer "beefiness" of the parts, and the weight reduction. I can lift this whole assembly myself and I couldn't lift the 203/205 assembly.
