bp71k5
3/4 ton status
Update 02/04/2018:
Cleaning and finishing some easy projects.
Sun visors are kinda nice driving near dusk. I simply got rid of the cardboard and vinyl portions of the stock ones and riveted a piece of plexiglass on instead. The shape of the stock one interfered with my cage bars so this one is designed to fold up and not interfere. I may paint them eventually, but they look ok even with exposed rivets.
And I needed more workbench space. Tons of YouTube videos of ideas and that's kinda where this came from. Just a shallow drawer for really long stuff that can't fit in normal size cabinets.
Used a piano hinge and a 3/4" piece of oak plywood for the top. Added a small overhang so I could clamp things to the edge when drilling or sanding.
When it's closed, it matches up with my other workbench so I have enough space to work on projects as big as 4x8 foot sheets
And cut another piece of plexiglass for these waterproof marine speakers. I like the way they sound, but the white color isn't working. Maybe by the time I care about it, they'll have some black ones available.
And got rid of the amps under the seats. The wiring was just too much of a hassle and I'm not sure I need 1000watts of music at my age anymore. The small 300w amp is right below the nonfunctional heater controls and is just a couple pieces of bent aluminum with the CB mount bolted across. I don't use the CB, except for Moab so I can mount it at plug it in later if needed
Can see the small amp up there.
Now I'm noticing the wiring isn't organized as well as I'd like. Will probably do something about that later if I ever decide to add an aftermarket ac/heater unit.
