bp71k5
3/4 ton status
Is this the first-gen burb?
Ah, I'd never be able to make that happen.
Ah, I'd never be able to make that happen.Is this the first-gen burb?Ah, I'd never be able to make that happen.
Those A-pillar supports were on a long backorder
Nice Fix!
Is it just that the flange from the interior patch panel is creating the gap,
Update: I'm confused
So as I was preparing the different patch panels to fit on the body, I noticed the hinge hole area on the A-Pillar had a couple tears in it. Ugh, it never seems to stop.
I did the standard drill holes at edges and grind out the torn metal and welded it back up.
Here you can see where I'm confused. The inner cab patch panel appears to overlap the inner rocker panel like I have shown. The confusing part is that it looks like the two lower holes in the corner post don't sit flush against the inner rocker panel. (There's a small gap at the bottom)
When I look at my early pictures, I can see evidence of this same strip of metal near the top two holes and it just looks like the factory didn't mind that. Anyone else see this or have any idea if I'm putting this together right?
