bp71k5
3/4 ton status
Update: Stereo rebuild
Since the new electrical system is about complete, I decided to rebuild the stereo which I built in this other thread:
http://coloradok5.com/forums/showthread.php?p=1897503#post1897503
The problem was that the mounting brackets I built weren't really keeping the unit lined up in the dash "hole" anymore and it was really difficult to deal with the wiring so i removed it from the dash and set about looking for some kind of way to actually mount it using the two radio "knob" locations in the dash.
Turns out a 7/8" compression fitting is just about the right size to fit within the holes in the dash. After some cutting and drilling some aluminum angle stock, I came up with this:
The plan is to fasten the radio and the faceplate to a rigid aluminum frame that attaches exactly the same as the stock radio. The two holes in the front and a single hangar in the back kinda like this:
More to come later. I even finished the rear bumper enough to bolt it back together and drive it.
