bp71k5
3/4 ton status
Update: 01/22/12- Rocker cover repair.
This rocker was crunched more seriously that I initially thought. Note backside of the welds from my initial floor repair are rusty. I'll definately need to clean all that up and protect it. Also, the inner flat wall is crunched almost 90% of the way up.
Some careful hammering, and tweaking with a masonry hammer which turned out to be pretty useful in reaching back there to push the metal back out. Still not 100%, but it's close enough for now.
Then it was on to address the door gaps.
Here's the passenger side. It's actually pretty good. I guess the rocker crash bent the body up a bit some and close the gap.
Here's the drivers. Note the top of the vent window is crashing into the windshield.
By my estimation with how the hardtop needing about 1/2" more room to fit correctly, I determined that the top of the windshield needs to move 1/2" forward. I had to use very complicated math to come up with that figure.
I marked the existing location of the windshield with my trusty plumb bob.
And I created this door hinge spreader that can adapt to my porta power tool. I just welded some square tube to an old door hinge along with a fat washer on the other end with a hol big enough for the end the hydraulic tool. I was worried that the windshield would be really difficult to move, but it was not a problem at all, the thing tilted foward 1/2" with not much resistance at all.
And here's the shot it moved forward 1/2". When I released the pressure, it even stays about 1/4" forward of where it started. Now I just need to figure out how to brace it there when I take the jack out to do the other side.
That should be nice and stout when you're done with it. Nice work.
