isnt this the same ram u got? http://www.harborfreight.com/8-ton-long-ram-air-hydraulic-jack-94562.html
You can un bend that, Just need a large object that holds down something that you can slip the end of the tube in then just pull really hard on the other end.
good point, i didnt think about thatLike most things in life, the tools are only as good as the person using them..... You can build a good cage with a cement floor and chalk or with a $250 piece of software.
The software is great and definitely saves time once you learn it... The money you save by not wasting tube helps pay for the software really fast, but remember that you'll "invest" some money in tubing to get the software 100% calibrated and figuring out spring back values for various bend degrees.
-G
