I would like to say you will get used to it, but Ive been down south 5 years and still havent
The heat is a different kind of heat.
07/31/2019
Been spending time unpacking and getting rid of trash and some stuff the previous owners of the house left. The county has some “convenience centers” that take as much trash as I can fit in a pickup once each day for free. I’ve been 4 times so far. Tonight was the final batch of previous owner stuff, an old washer and dryer I was able to sell for $300.
So now the garage is close to only having in it what’s supposed to be there. I’ve never had a garage that we actually parked cars in and given the rain here, I’m going to try and keep this 2 car garage able to fit 2 cars (or 1 car and 1 K5).
K5 is going on the far side with all the tools. Since I lost all my old garage shelving, I’m paying close attention to storage options. My big base toolbox was damaged in the move and a couple drawers don’t close anymore. I blame the movers.
I have a little over 10ft of horizontal space on that back wall for wall cabinets. With a 9.5’ ceiling, I could fit some 48” cabinets all the way up at the ceiling and a 36” tall workbench or deeper cabinets below. Maybe replace my broken toolbox with a couple fixed cabinets as I never move the big toolbox
That right side has a couple windows that I can fit a couple more cabinets up high if needed. I think that wall might be good for “portable” tools on wheels like the bender, hoist, etc. I can wheel them out if I need extra room to work on something.
I also have been looking at work tables and ran across these things. They make welding table kits like this one.... https://weldtables.com/collections/...ng-table-top-kit-certiflat-by-tab-slot-u-weld
Or they make higher-end ones too. I think if I can make some kind of wheeled stand for it that lets me fold the table top down, I can roll it over against that side wall when not in use which would leave space for parking the rest of the time.
I also sold my tablesaw back home as I hated that particular saw, but really enjoy having a tablesaw. There’s a bunch of “wood shop” projects around the house so I took the opportunity to get what I hope will be an upgrade to my old saw. I really love the worm drive circular saws and when I saw this wormdrive tablesaw, I decided to give it a try. It’s certainly nothing Norm Abram would use for cabinets, but I’m hoping once I make a stand for it that it’ll be fine.
One of the things I hated about my old one was the stand was flimsy and the wheels didn’t lock well. Since this doesn’t have a stand, I get to build a stand correctly.
The smaller motor with worm-drive gears is supposed to make it cut through lumber much easier without binding, and makes it a bit lighter. I can actually lift this up myself and place it on a future shelf on a wall.
The smaller motor also leaves some space for clever tool storage underneath. Also designed so it can safely sit up on end to take up less floor space.
View attachment 310026 View attachment 310027 View attachment 310028 View attachment 310029
That’s it for now. Next up is finding a bit more chairs and other furniture that I’m not planning to build, then getting some garage storage installed to make room to be able to build some built-in bookshelves and a cal-king sized bed frame for me and Mrs. BP.
Is that space above the garage ceiling a storage area, or 2nd story living space?
-G
They have a small red rotating ring that lowers a stabilizer foot so the table doesn’t move while your using it. I always hated my other tables because they’d move around so much even with the caster locked.
I really wan to do a similar style table for my garage. Not sure I can fit it though.Made a decent amount of progress over the past few weeks.
Got an decently sturdy ceiling shelf installed with clear plastic bins so I can see what’s inside before I climb up the ladder and fumble with them. (Thanks for the idea Greg) Supposed to hold 600lbs.
View attachment 312519 View attachment 312520
That cleared up almost all of my boxes and allowed me to rearrange some of the tools off the floor. Next up was the workbench.
Ordered a 3’x 4’ pro table from weldtables.com. It came within ~10 days. It came unassembled to save shipping space I thought, but it was assembled in the crate with some wood and screws holding it together. I guess welding it myself saves a bit of money.
View attachment 312521 View attachment 312522
Also had to refill my welding gas. The local air gas didn’t carry the 60lb bottles so I got to upgrade to an 80lb.
The table is supposed to be capable of being really flat using a series of tabs and slots on the ribs that engage with slots on the table top. The quality seems to be very good on the parts themselves. Welding it together flat wasn’t quite as easy as they made it seem, more on that later. Essentially I clamped it all together with a bunch of 3” pipe clamps on the interior and C-clamps on the edges. Then starting near the center, zapped the ribs to the table in about 1” sections.
View attachment 312525 View attachment 312526
I didn’t actually put any welds in the top surface. When I check for flatness with a big straightedge there’s a couple high spots which seem to be right over some of the X areas where the tabs on the lower ribs poke through. Looks like some heat distortion and I wonder if I weld up those holes, that it might shrink back down? As an alternative, a flap disc seems like it would fix it.
One neat thing about the tables with the holes every 2” is that I can place 5/8” bolts in the holes to act as stops that are at right angles which makes setting up some table legs a bit easier.
View attachment 312530 View attachment 312531
Nothing fancy. Just 1.75” square tube. I call the ends and tapped them for 1/2-13 flat head Allen bolts to hold the top down to the legs.
I do like these casters I found. They hold 600lbs each for a total of 2400lbs. I hope that’s enough.They have a small red rotating ring that lowers a stabilizer foot so the table doesn’t move while your using it. I always hated my other tables because they’d move around so much even with the caster locked.
View attachment 312533 View attachment 312534
It rolls around great, and I’ve seen some good DIY clamps that fit into the holes that should work for both woodworking and K5 stuff. Future plans include a bracket to attach the table saw, grinder, and a few other things to the table as well.
Looking at it I was thinking it may be worth adding a shelf under neath that could hold some tools. Feel like a chop saw would be at home under there.
Maybe, there’s room for a small shelf or bars up near the top, but I designed this to be at close to normal table height so I can sit down and work on it. Although I didn’t consider what molten blobs of steel would do to my knees as they fall through the holes while welding. No more shorts or barefoot welding I guess.
You can't tell us about cool casters and then not provide a link. That's against forum rules!![]()
I'll be you could come up with a small splatter shield underneath to divert welding slag from falling on your legs.
A commercial-grade power strip mounted under the lip on one side would be a nice addition too. I use mine all the time for grinders and cutoff wheels.... ended up being really valuable. Not draping the cords off to a wall outlet also saves accidentally pulling the cutoff wheels onto the floor and breaking them. (It's always when you've just loaded a fresh one onto the grinder too! )
-G
