Those are new discs I'm putting in with the "new" axle. Haven't quite figured out the e-brake yet. Been waiting to see what Dan @ Ruffstuff was gonna come up with. Just gonna run the standard 3/4 ton calipers for now.
. Based on the bushings that were sent (I assumed they would fit) I drilled out one of the 7/16" inch holes in each shackle to 9/16"...I was thinking 7/16" at the frame and 9/16" at the spring-eye. So...I'm dead in the water right now until I can get the right set of bushings and figure out how to handle the shackles. Worst case scenario, I can use the original wimpy front shackles until I correct the DIY4X ones.
Are you going to repaint? Looks good. Any updates?
Bruiser
What?? You don't like the paint?
Only in dark blue.
