She's a great base for a build. I live in the rust belt and Newfoundland uses road salt in the winter time. So to find a truck with a perfect chassis and for the frame not to be cracked at the steering box is a rare find around here.Yes, OD is mainly for the highway.
Looks like a great truck to dive into building into what you will have fun with!
If my memory is correct, one of my trucks is just switched ignition power going through the rocker switch, directly to the TCC solenoid. It's internally grounded. I believe that the other has power going into the transmission and the manual switch is on the ground wire for the TCC.
Both trucks are not using the internal pressure switch, so that I can lock it in 2nd, D and OD. I wanted to be able to lock it in drive. I have used the lock-up in 2nd in my K10 to cool the transmission down. (I had been running it slightly aggressively up Imogene Pass to catch up to another truck.)
I haven't ever bothered to install a brake switch in either of them. Laziness, mainly, but it keeps engine braking this way. Lol!
All that makes sense and sounds simple enough. If you lock the torque converter in say 3rd gear. Does it stay in 3rd till u unlock it? Potentially causing you to stall the engine? Still new to these old auto trans. Always had a manual lol.
