Going to take a Texas build to pull that off from the brotherhood.
Thought the plan was to get the truck to the bash this year ?
What year is this?
-G
So I have a question for ya Greg, why not blow in insulation in the walls? Then run your wires through conduit on the outside of the sheetrock. I actually prefer the airlines on the outside. As changes are much easier to do.
I realize the wires in conduit can be somewhat annoying but it's a whole lot faster, as is the blow in insulation
Go closed cell. Your HOA will love you for it.... The sound deadening is awesome... And a full wrapped metal garage door has an R18 I think and also helps with sound.... Something to think about
life goal = soundproof shop...
I’ll second the concern over gypsum in a garage shop space. Shiplap and other reclaimed siding (flipped to the backside showing) has worked well for my space, and it’s been banged pretty good by materials and parts and my truck. Lots of margin for operator error.I’ve always thought it was too weak for shop walls.
I'm doing 5/8 sheetrock on mine.
So are you reconfiguring the trusses and opening up the ceiling?
Honest question... why 5/8’s? The added strength.... fire? I don’t really see the advantage of adding 5/8 unless it was for fire. It’s just not that more “puncture proof” over simple half and it’s not very fun if you get it in 12’s or 14’s for hanging.
His roof is a cut and stack roof, no truss. By code you can’t cut trusses without engineering. Cut and stack you can do what ever you want. Three beams, some framing and some 2x6 hangers and he has his old mezzanine back.
