So you are saying that only now you are thinking about doing this, I thought it was the plan since you chose to put ORIs.
Just remember you want to try and get it finished before Danger is too old to want to be with you.![]()
Iceman, I've got all SORTS of crazy ideas floating around in my head all the time (remember the automatic fender-tapering sheetmetal idea?).... the point, I suppose is that not all ideas are good and some that ARE good may simply not be worth the effort or expense.
In this case, I'm figuring out the last few bulky items to package under the truck (Dual batteries, dual air compressors, dual air storage tanks).... and will quickly move on to smaller items (air control solenoids, distribution manifolds, etc)..... then it's time to figure out routing for fuel lines, brake lines, air lines, axle breather lines, etc. If I'm going to run braided lines for nitrogen fill then now is the time to make the commitment and figure out the routing and placement of the shutoff valves, etc.
This one isn't really going too far off the build path, and it seems like the end result would justify the expense of extra components and a bit more effort in the packaging of the lines underneath the truck.
-G
